Thread: FTP Block Error: 503 Bad Sequence of commands.
    Default FTP Block Error: 503 Bad Sequence of commands.
    Hello everyone,
    I am trying to send a local file to a FTP server using FTP block in Stratonng, Zenon EE 8.10.
    All i could find on Help Manual is Inputs & Outputs of the block. Output Inst_FTP.STAT always shows 503. Acording to wikipedia page List_of_FTP_server_return_codes 503 means "Bad Sequence of Commands.
    How i used is:
    Inst_FTP('192.168.1.250','192.168.1.35','ftpkoztek ','******,'','','','','C:\Data_Rec\Arc\','First_Fi le.zip', '/Koztek/File_io_deneme/','','',3,enabled);
    Manual says:
    Inst_FTP2( IPSERVER(*STRING*), IPCLIENT(*STRING*), USER(*STRING*), PASSWORD(*STRING*), LIST_DIRECTORY(*STRING*), GET_REMOTEFILEPATH(*STRING*), GET_LOCALDIRECTORY(*STRING*), GET_REMOTEFILENAME(*STRING*), PUT_LOCALFILEPATH(*STRING*), PUT_LOCALFILENAME(*STRING*), PUT_REMOTEDIRECTORY(*STRING*), DEL_REMOTEFILEPATH(*STRING*), DEL_REMOTEFILENAME(*STRING*), OPERATION(*UINT*), ENABLED(*BOOL*) )
    with the remark "Keep inputs which are not necessary empty."
    I double checked IP addresses, username, password, path and file names. Even if I change them to some other form same return code shows up.
    What am i doing wrong? Is there any working example of this code?
    Thanks in Advance!
    Default Re: FTP Block Error: 503 Bad Sequence of commands.
    Found the problem. Even though manual says "Keep inputs which are not necessary empty." and all i use was operation 3 (put), the problem was that you can not leave "LIST_DIRECTORY" empty. Putting a '\' solves the problem.
    "LIST_DIRECTORY" -> '\'
    Hope this helps someone like me.
    Best Regards.
    Emir Tuğcan Gençer
  1. canOpen coWriteParam function block
    By mos89 in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 7th June 2018, 11:39
  2. Developping C function block
    By kwangyol in forum Engineering Studio Logic & Logic Service (former zenon Logic Workbench & Runtime)
    Last Post: 29th March 2017, 10:26
  3. VSTA block array
    By nirren1992 in forum VSTA
    Last Post: 24th March 2017, 07:43
  4. VSTA block array
    By nirren1992 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
