Thread: Bar display - Zenon logic
    16.03.2020
    Default Bar display - Zenon logic
    When i increase UINT variable (for example, variable+100) in Zenon Logic, the bar display gets filled to the top, not to 100. Why is that happening?
    Milan
    919
    Default Re: Bar display - Zenon logic
    what "bar display" in zenon Logic do you mean?
    16.03.2020
    Bar display from screen elements tab in Zenon Editor. I created a screen and put a bar display, and i want to simulate increase of water level in Zenon Logic with a timer. When i start Runtime and simulation, and time (example 30s) set to timer passes value of a variable increases to 100, but bar display on a screen does not show value of 100
    This is what i get:
    919
    Check if the variable in zenon has correctly configured as well signal as measuring ranges. Maybe (by data type change) you mistakenly "configured" the linear value adjustment.
    And by 'Bar display' element check the settings for 'Display range'.
  1. How can I display zenon Logic in zenon Runtime?
    By koizot in forum zenon Supervisor
    Last Post: 19th April 2019, 04:39
  2. Zenon Logic to check if a Zenon Variable is online
    By doublem in forum zenon Energy Edition
    Last Post: 28th March 2019, 13:06
  3. zenon logic doesn't communicate with external variables in zenon
    By mashjj in forum straton / zenon Logic
    Last Post: 27th February 2015, 13:10
  4. Re: zenon logic doesn't communicate with external variables in zenon
    By anjali.gk.nair@gmail.com in forum straton / zenon Logic
    Last Post: 22nd August 2014, 10:51
  5. Zenon logic
    By sidramsatyal in forum straton / zenon Logic
    Last Post: 1st July 2014, 09:45
