Thread: ProductionFacilityScheduler - can't set CountryName property
    31.05.2018
    5
    Default ProductionFacilityScheduler - can't set CountryName property
    Hello all,
    I've found yet another problem with ProductionFacilityScheduler object in AddIn Framework. Trying to set the value of CountryName property throws the exception (Unable to write read-only property) even though that Help hints that technically it is possible to change it during Runtime.
    Is there any workaround for it?
    Mikolaj
    31.05.2018
    5
    Default Re: ProductionFacilityScheduler - can't set CountryName property
    Unsuprisingly the problem persists also when trying to set the property via COM. Any ideas?
    Code:
    zenonProject = ((zenOn.Application)Marshal.GetActiveObject("zenOn.Application")).Projects().Item("TestProj");
    zenonProject.Pfs().CountryName = lang;
    02.02.2012
    15
    Hello mwieczorkiewicz,
    I had I quick look on it and I think, it could be bug. Please get in contact with your local COPA-DATA support (support.cee@copadata.com).
    You should tell them the exact zenon version you are using (main version and build number) and your serial number. A zenon test project with a visual studio solution to reproduce it easy, should also be handed over.
    Kind regards,
    martin
  1. XAML property
    By banpr1 in forum VSTA
    Last Post: 21st November 2019, 03:11
  2. Replies: 3
    Last Post: 26th February 2019, 16:34
  3. Replies: 4
    Last Post: 25th January 2017, 00:28
  4. Changing Iamge BackgroundImage property
    By davide.galigani in forum VBA
    Last Post: 1st June 2010, 01:13
  5. Parameters in Property window greyed out?
    By dak2483 in forum zenon Supervisor
    Last Post: 25th September 2008, 14:24
