Thread: Statistics in Process Gateway
    15.07.2019
    9
    Frage Statistics in Process Gateway
    Dear zenon support team,
    I need to send some data in Modbus TCP/IP so I configured Process Gateway Modbus Slave and select some signals for testing. I checked the connection with a certain Modbus Master Simulator and it receives data from selected signals. It seems everything is OK but I noticed there is no update in Statistics section (Process Gateway window). Did I miss to configure something else?
    I appreciate your help.
    PD1: I am sharing some screenshots with you.
    PD2: zenon Energy Edition version is 8.10 Build 61858.
    Jose_Alejandro
    Attached Thumbnails Attached Thumbnails Modbus_Master.png   Process_Gateway_Modbus.png   Modbus_exported_signals.png
    1,039
    Default Re: Statistics in Process Gateway
    The window is general - common for all protocols supported by zenon Process Gateway. I suppose in Modbus this Information is not available.
    As this is not an Energy-specific topic, Iím moving this post to another forum node.
  1. Process Gateway and IEC870slave
    By mehrdad66 in forum Gateways
    Last Post: 18th August 2020, 13:52
  2. Process gateway connection problems
    By gunhunter in forum Engineering Studio & Service Engine
    Last Post: 8th December 2017, 03:07
  3. Process Gateway
    By murphys in forum Gateways
    Last Post: 8th February 2011, 09:45
  4. DNP- Process Gateway
    By hoscillada in forum Gateways
    Last Post: 17th December 2009, 05:48
  5. Process Gateway
    Last Post: 8th November 2009, 22:57
