Thread: Error in compiling ('buid start up project') in logic processor
    04.06.2020
    3
    Default Error in compiling ('buid start up project') in logic processor
    While compiling the project in the logic editor, I am getting errors on the of the  program- see snapshot below.Have you seen this error message earlier? If so, how do I fix it?
    BR,
    Deepak
    18.12.2017
    23
    Default Re: Error in compiling ('buid start up project') in logic processor
    Hi!
    Your program is to big!
    64KB is max for a POU.
    https://forum.copadata.com/showthread.php?3790-Warning-limit-is-64KB
    Split the code over more programs.
    br,
    Fredrik
    04.06.2020
    3
    Hi Fredrik,
    What does POU size refer to- size of the logic processor OR number/ size of the programs within the logic processor OR number of lines of code within the program?
    BR,
    Deepak
    18.12.2017
    23
    Hi!
    POU is one Program Organization Units, as described in the other thread. 64K is size.
    "Quality" is one POU, as "Analog", "Digital" and "main". You could create "Quality2" and "Quality3" and distribute your code into 3 programs instead.
    The limit is 32000 POUs.
    /Fredrik
  1. Openning Logic project in Editor Using Macros
    By eunsang7375 in forum VBA
    Last Post: 18th April 2019, 07:14
  2. How to start and stop driver simulation project from runtime?
    By altera in forum straton / zenon Logic
    Last Post: 9th June 2013, 23:25
  3. The project does not start If ...
    By natali in forum zenon Supervisor
    Last Post: 4th February 2013, 00:11
  4. No start project was found!
    By douglasm in forum zenon Operator
    Last Post: 23rd June 2009, 07:33
  5. Processor type
    Last Post: 19th September 2007, 16:15
