Thread: Web Client setup error
    11.04.2019
    20
    Default Web Client setup error
    I'm trying to setup webclient on a computer.
    Server & WebClient computer is Windows10, Zenon version  is 8.10  Build 57250.
    The webserver is a staqndalone Zenon runtime computer, ISS is running and Zenon webserver is running.
    First I tried to click on the webclient setup shortcut that is displayed on the http://IP.xxx/zenon page, but it failed, freezed and nothing happend.
    Then I tried to mount Zenon install dvd iso, started setup selected Webclient from the installwizard, but then I got this error 1904
    Any Ideas how to proceed?
    /Regards Tobias
    03.11.2015
    66
    Default Re: Web Client setup error
    Hi Tobias,
    If you have the web server running and try to install the web client on the same machine, the zenNetSrv service cannot be stopped.
    make sure to stop all zenon Programs & Services before installing the web client.
    I would also recommend to run the setup as administrator. You can also use the "zenWebClient.exe" instead of the "*_small.exe" in C:\Inetpub\wwwroot\zenon\controlversion
    Please note that you cannot run the Web Client on the same machine as the Runtime Server.
    BR,
    Joris
    11.04.2019
    20
    Hi
    I tried Run as Administrator, but, the installation program only allows me to make uninstall right now, if i do that, uninstall gets interrupted, so Im kind of stuck in this position.
    03.11.2015
    66
    Quote Originally Posted by Tobiasto View Post
    Hi
    Hi Tobais,
    Have you checked on the running services?
    Is there zenNetSrv And/or other zenon services running while you try to install?
    Is the .Net Framework 3.5 installed on the PC?
  1. Version number error in Web Client
    By joelprasad in forum Smart Server & Smart Client (former Webserver & Webclient Setup)
    Last Post: 7th February 2018, 14:11
  2. Sicam 230 web Client - InitInstance Error
    By arrols in forum Smart Server & Smart Client (former Webserver & Webclient Setup)
    Last Post: 10th November 2016, 11:17
  3. Zenon Web Client installation error
    By ruan in forum Smart Server & Smart Client (former Webserver & Webclient Setup)
    Last Post: 3rd February 2016, 14:42
  4. Web Client Error
    By yitlilee in forum Smart Server & Smart Client (former Webserver & Webclient Setup)
    Last Post: 24th February 2015, 20:33
  5. Web client subprojects error
    By jurijcadez in forum Smart Server & Smart Client (former Webserver & Webclient)
    Last Post: 17th May 2012, 23:34
