Thread: Project symbol library zenon 7.60 - problem
    01.02.2016
    37
    Default Project symbol library zenon 7.60 - problem
    Hi all,
    In project symbol library I have symbol with name 'Symbol 6'. That symbol is already used on screens.
    When I changed the symbol name, it is not either usable, and all symbols on screen is empty?
    Is it possible to change symbol name already used on screens?
    How to update screens to use same symbol but with different name?
    BR,
    MK
    10.12.2007
    261
    Default AW: Project symbol library zenon 7.60 - problem
    afaik the linked symbols are identificated by their names, so this is not possible out of the box. But you could export the pictures as xml and then replace the names in the xml file and import it back. Should work, but make a project backup before
  1. Symbol library encryption
    By konsistek in forum zenon Energy Edition
    Last Post: 17th March 2020, 09:45
  2. Symbol Library
    By Olesia in forum zenon Service Engine Supervisor
    Last Post: 24th October 2017, 12:16
  3. Replies: 2
    Last Post: 10th May 2013, 16:40
  4. Replies: 2
    Last Post: 8th April 2013, 00:28
  5. Combined element and symbol library problem...
    By marduv in forum zenon Service Engine Supervisor
    Last Post: 28th July 2010, 23:41
