Thread: SQL Export Variable ID / Custom column?
    03.10.2019
    Frage SQL Export Variable ID / Custom column?
    Hi!
    We're using the SQL Export module for archiving.
    Our planners/supply chain have asked for some changes in the way the data in the SQL is presented due to some slight inconveniences.
    First up, is it possible to change the Variable ID somehow?
    Unfortunately, we have multiple identical Varible IDs across different Projects, which is causing a hassle for them.
    Second (which could also spare us from the issue mentioned above), is it possible to add another column with the variable identification for instance?
    Or something simlilar.
    Erik
    Zenon 8.00
    218
    Default Re: SQL Export Variable ID / Custom column?
    Dear ErikChristensen,
    are you using the SQL export or the built in SQL-evacuation of zenon historian module?
  1. Replies: 0
    Last Post: 10th January 2020, 12:25
  2. Variable XML export/import
    By isidormac in forum zenon Supervisor
    Last Post: 31st October 2018, 17:59
  3. Custom filter
    By MotionEngineering in forum zenon Supervisor
    Last Post: 25th September 2017, 11:34
  4. Replies: 1
    Last Post: 26th May 2017, 08:18
  5. Variable's name in CEL without the column
    By cyrilfeasy in forum zenon Supervisor
    Last Post: 21st January 2010, 00:57
