Thread: Zenon directly with ABB PLC
    12.03.2020
    3
    Default Zenon directly with ABB PLC
    Hello all,
    Greetings
    I'm new to the Zenon . My project is to collect some data from remotely placed PLCs to my Zenon SCADA. I was thinking of taking Kepware as an OPC to communicate them together with the usage of the Modbus TCP/IP protocol. But i heard that it is possible to connect directly to the Zenon without using any OPC .Using direct Modbus TCP/IP.
    If anyone can explain if it is possible
    If yes how can i do that I'm a newbie here hope you got my situation and you will sort it out
    BR
    Amal
    987
    Default Re: Zenon directly with ABB PLC
    yes, in zenon for communication with Modbus devices via TCP/IP you can use driver MODRTU.
    I propose you to make the online basic training in zenon.
  1. Replies: 3
    Last Post: 12th December 2019, 12:06
