Thread: Zenon network - bandwidth requirements
    17.03.2016
    62
    Frage Zenon network - bandwidth requirements
    Afternoon,
    Has there been any testing to determine the bandwidth requirements for Zenon network? I.e. what is the minimum required connection speed between 2 servers or a server and a client? Any maximum on latency?
    We are considering a network which utilises DSL connections via copper pilot cable to remote ends of a site (no fibre or cat5 connectivity). DSL devices present a network as a single LAN (so normal TCP traffic is not a problem), however, it has lower line speeds than there would be with 10base-T ethernet connecting the 2 points.
    I understand the answer might be a bit 'depends on the number of variables' etc, but am curious if CD have conducted any testing? Would there be any specfic recommendations to ensure system works better (maybe 'Permanently read varaibles' turned on etc).
    Zenon Client <-ETH-> Switch / DSL <----------------DSL-----------------> DSL / Switch <-ETH-> Zenon Server
    Example type device eg Westermo DDW-226. Would a baud rate of 1024000 = 1Mbps be quick enough?
    Thanks,
    Dave
    18.12.2017
    23
    Default Re: Zenon network - bandwidth requirements
    Hi!
    Activating "Permanently read variables" will increase the network traffic. It will force the driver to poll variables, regardless if they are used or not.
    After the client has synchronized the project files, like screens and settings, only the relevant data for the active screen will be transferred between the server and the client.
    If you check the requirements in the help file: Manual > Installation and updates > System requirements > Hardware requirements > Runtime, the minimum requirements for client/server projects are 64 kBits/s.
    Avoid trends using large amount of data by creating aggregated archives.
    Best regards
    Fredrik
    17.03.2016
    62
    Quote Originally Posted by FredrikV View Post
    Hi!
    Best regards
    Fredrik
    Thats great, thanks Fredrik
  1. zenon network migration
    By LewisH95 in forum zenon Network
    Last Post: 12th November 2019, 09:15
  2. Network Traffic Report in Zenon
    By jose.torres@indexum.com in forum zenon Supervisor
    Last Post: 25th July 2019, 10:21
  3. Hardware Requirements
    By jose.torres@indexum.com in forum zenon Energy Edition
    Last Post: 19th January 2018, 17:37
  4. Hardware Requirements (General)
    Last Post: 15th January 2015, 20:09
  5. what is the minimum system requirements of your ZenOn products?
    By lephis in forum Editor and Runtime Setup
    Last Post: 8th February 2010, 08:27
