Thread: AD authentication without joining server to the domain
    28.04.2020
    4
    Default AD authentication without joining server to the domain
    I would like to ask if it is possible to use the Domain controller as authorization authority without joining the PCs to the domain?
    Technically this could simply work with LDAP(S).
    If this is not currently implemented, is there any way to add new/external (developed by you or by the customer) authentication/authorization provider to the runtime - does the architecture of the application permists decoupling of these providers by use of some interfaces?
    We alfready have Zenon on some production lines, but there is an ongoing project for a new line - that will also have Zenon. For the current line, the HMI PCs are joint to the domain, which presents some problems, because it is not in line with the S95 architecture. We would like to make the new and the old line fit into the architecture. The builders are not fully aware of the possibilities of your system. But these are not really forum topcis...
    Default Re: AD authentication without joining server to the domain
    Hi zorgoz,
    Thanks for your post and welcome to the forum
    From zenon version 8.00 it is possible to use AD users at login in the runtime, also when the system on which the runtime is running is not a member of the domain and the runtime process is not started in the user context of a domain user.
    28.04.2020
    4
    Hi Mark!
    That is great! Can you point me to a documentation page, that is describes this feature, its requirements and the way to set it up? Could it work behind an LDAP proxy like the setup described here: https://wiki.samba.org/index.php/Ope...as_proxy_to_AD?
    Thank you!
  1. Linking Users to corporate Domain account
    By Xavier in forum zenon Energy Edition
    Last Post: 18th July 2019, 08:04
  2. Domain user with MAN profile
    By sicam_user in forum zenon Supervisor
    Last Post: 24th September 2013, 20:31
  3. Replies: 5
    Last Post: 26th July 2010, 06:52
