Thread: 104 Driver Error
    19.05.2017
    6
    Default 104 Driver Error
    Good Afternoon,
    I am adjusting an old V460 project, made in version 6.51.
    The project is running correctly in a substation and I am using the back-up of this system.
    To configure the project I am running VMware with windows XP on a windows 10 computer.
    When I Restore my project back up I can run the runtime but I get the following error:
    Zenon version : 6.51 sp0 build5
    ms windows ver. 5.1service pack 3
    Processor: x86
    Exception code C0000006
    The same error I get when I try to open my IEC 60870-5-101_104 driver. (Found under Sprecher Automation).
    The run time opens all other drivers but this one.
    I get the same error when i try to open other projects made in version 6.51 in this VMware and a colleague gets the same error when opening in another VMware.
    What causes this error and how am I able to fix it?
    1,059
    Default Re: 104 Driver Error
    The V640 - von SPRECHER Automation - contains own driver for IEC 60870-5-104 communication: Sprecon870.
    Thus, the zenon native driver - IEC870 - does not work on this OEM. By problems with a V460 project I propose you to contact SPRECHER.
  1. Replies: 2
    Last Post: 19th May 2018, 06:19
  2. DNP Driver Error...
    By daujivar in forum Drivers
    Last Post: 7th June 2013, 06:28
  3. Replies: 0
    Last Post: 15th November 2007, 13:32
