Thread: Elements in Variables & Functions Modules cannot be added/modified in a Multi-user project
    17.02.2020
    18
    Default Elements in Variables & Functions Modules cannot be added/modified in a Multi-user project
    I set up a Multi-user project in a local server. afterwards I accessed this projects through 3 other client computers. Two of these clients are able to edit this project normally.
    The third client however cannot add/modify Elements in Variables & Functions Modules only. Whenever this client tries to do so, a "parameter is wrong" error appears.
    I realize that when a certain module is locked be a client, other clients cannot modify that module. This is different, It happens even when the client in question creates a new Multi-user project and no other client has accessed this new projects. Other clients that access this new project afterwards are able to modify the project normally.
    What could be the problem?
    Thanks in advance.
    28.02.2013
    207
    Default Re: Elements in Variables & Functions Modules cannot be added/modified in a Multi-user project
    Dear Anas,
    are all clients using the same zenon Version?
    Felix
    17.02.2020
    18
    Dear Anas,
    Felix
    You were right. The client in question was using an older version.
    Many thanks.
  1. Replies: 3
    Last Post: 10th March 2019, 06:05
  2. Replies: 1
    Last Post: 28th August 2018, 08:45
  3. Multi user variable administration
    By nkadishi in forum zenon Supervisor
    Last Post: 2nd January 2017, 18:51
  4. Versioning in the multi-user projct
    By amigo in forum zenon Supervisor
    Last Post: 11th May 2016, 18:16
  5. Replies: 1
    Last Post: 26th April 2016, 09:19
