Thread: ZenDbSrv Issuse
    30.01.2018
    Beitrag ZenDbSrv Issuse
    I have an issue in Opening the Workspace/Eidtor.
    While opening the editor, Error is Showing as ZenDBSer.exe not running. When Internet is disconnected from PC, then its working fine.
    Zenon Version used : Zenon Energy Edition 8.00
    I tried doing standard registration, SQL service 2012 restart and Reinstallation of Zenon But no success.
    Can any one help me out to fix this is issue.
    17.03.2016
    62
    Default Re: ZenDbSrv Issuse
    Have you changed any of the settings for 'listening ports' in the Startup tool (under Application > Options > Listening Ports)?
    If the problem is related to it not working only when the internet is plugged in or not then its most likely something to do with the interface the DB service is looking for changing.
    You can set the service to listen on a particular interface, particular IP or any interface. Perhaps when plugging in your internet connection the routes are changing or home address of 127.0.0.1 is somehow being redirected?
  1. zenDBSrv.exe is not responding
    By Diana7310 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 7th August 2018, 06:20
  2. zenDBsrv
    By mehrdad6687 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 28th August 2017, 10:00
  3. zenDBsrv
    By mehrdad6687 in forum zenon Energy Edition
    Last Post: 27th August 2017, 20:19
  4. zenDBsrv
    By mehrdad6687 in forum Diagnosis Tools
    Last Post: 25th August 2017, 13:50
  5. Zenon energy edition 7.50 SP0 zendbsrv is not running
    Last Post: 22nd December 2016, 14:45
