Thread: archive timing
    10.02.2020
    3
    Default archive timing
    Dear Team,
    i need to know if its possible to start archiving from 5AM every day.
    i need to do daily report with this archiving and the report will be generated at 5:01 AM so when i put in the archive settings (start of archiving) at 5 AM it will do it for the first day only the next day the archive will be saved at 12AM.
    thanks for you support.
    870
    Default Re: archive timing
    I'm nor sure what is your use-case.
    From archived data you can trigger a report at particular time via 'Time control' module. A report does not demand that the Historian was started at the same/similar time, it only demands that the data was archived. And in your reports you can use the time filter to evaluate the data from wished period.
  1. About Zenon archive
    By gadre14 in forum zenon Supervisor
    Last Post: 27th April 2019, 05:31
  2. Archive SQL export is not available
    By Lww in forum zenon Supervisor
    Last Post: 7th August 2017, 07:45
  3. Zenon archive issue (archive inactive)
    By eugenius in forum zenon Supervisor
    Last Post: 24th August 2012, 08:19
  4. Archive report
    Last Post: 10th August 2011, 02:34
  5. Archive vName
    By stimpfig in forum VBA
    Last Post: 10th May 2010, 15:14
