Showing results 1 to 7 of 7
Thread: Zenon process gateway.
    murphys Gast
    Default Zenon process gateway.
    I have been having some problems with this interface.
    It has been set up and worked fine for a while. Recently, the Update /Seconds figures on the configuration form have been question marks (??). The rest of the comms outside zenOn system are working fine, and show no errors in connection to process gateway.
    zenOn version is 6.20 SP 1.
    I have been considering a reboot when practical, but I would like to identify the cause.
    891
    Default Re: Zenon process gateway.
    6.20 SP1 it is already older zenon version. Which module are you using in your Process Gateway?
    murphys Gast
    Hi
    Yes, I understand there a later version(s), unfortunately not in a position to upgrade.
    Module is C:\Program Files\COPA-DATA\zenon620\zenprocgateway.exe
    Rebooted PC yesterday, problem went away.
    Still no wiser as to the cause.
    891
    OK.
    I'm asking ones more:
    Which module are you using in your Process Gateway? (Which protocol?)
    Each modul is a separate dll, with its-own window and statistic info...
    murphys Gast
    Sorry, Modbus Serial connection.
    891
    I haven’t found any info what could be the reason. But if you find some day how to reproduce the same effect ones more, please let me know, I will at least try it out in current version.
    murphys Gast
    Thanks.
    No failures since re-boot (13/12/2009). If I manage to unearth some evidfence, I will submit a post.
  1. Process Gateway IEC870SL
    By lunzer in forum Drivers
    Last Post: 8th August 2017, 12:28
  2. Process Gateway
