Thread: Time Sync using MODBUS Variable
    28.02.2020
    Default Time Sync using MODBUS Variable
    Hi guys.
    We don't have NTP. We need to sync time with DCS based on a trigger from dcs on 5 AM everyday. So DCS connected on MODBUS TCP will trigger bit called Time_sync everyday at 5 AM and when yhis trigger is received we need to set time in our runtime (windows based) copa data application for 5 am.
    Any one can help with the script for this please.
    18.12.2017
    23
    Default Re: Time Sync using MODBUS Variable
    Hi!
    There are probably many ways to do this. One simple way is with a Batch or Powershell-script.
    zenon use the OS clock. You need to set the clock in Windows. It require Admin rights.
    Create a Powershell script for setting the time and call it from zenon with a function of type "Start program" in the Windows section.
    Trigger the function in limit values or a REMA for the Modbus-variable, "Time_sync".
    Fredrik
  1. Replies: 4
    Last Post: 1st October 2019, 09:00
  2. Zenon Time Sync
    By Praveen Kumar Karthikeyan in forum zenon Supervisor
    Last Post: 3rd September 2019, 08:38
  3. Replies: 2
    Last Post: 29th March 2011, 10:46
  4. Real Variable Modbus TCP
    By pkreisel in forum Drivers
    Last Post: 15th February 2011, 23:39
  5. compare time variable with system time
    By flajoso in forum VBA
    Last Post: 25th August 2008, 06:47
