Thread: Allocation is not following the trigger variable status
    17.02.2020
    23
    Default Allocation is not following the trigger variable status
    I created an Allocation to allocate the value of a source variable to a target variable. this allocation is to be triggered by a binary trigger variable which toggles every 5 seconds.
    However, the target variable's value is changing as soon as there is a change in the source variable, regardless of the trigger variable state.
    I understand that "If no variable is linked, the allocation is spontaneous. This means that whenever the value of the source variable changes, it is automatically written to the target variable". But why is this happenning even when the trigger variable is linked?
    Thanks in advance.
    28.02.2013
    226
    Default Re: Allocation is not following the trigger variable status
    Dear Anas,
    the behaviour depends on the parameter trigger type. Here you can specify if the allocation shall be triggered on the rising edge of the trigger variable only or all the time while the trigger variable is true.
    Felix
    17.02.2020
    23
    Solved it. Once I changed the Target Variable's driver to Local, the Allocation started to behave as it should.
    Dear Anas,
    Felix
    Thanks Felix, the trigger type was right. The problem was with the variable driver.
  1. Replies: 1
    Last Post: 14th February 2020, 09:15
  2. trigger the Screen type action by variable
    By sgh66 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 8th November 2019, 11:10
  3. How to trigger a function when a variable changed?
    By denver in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 16th May 2012, 10:12
  4. Replies: 3
    Last Post: 5th April 2011, 09:16
  5. SQL variables allocation problem
    By rloureiro in forum Drivers
    Last Post: 13th March 2008, 13:32
