Thread: How to assign a certain entry in an archive to a variable?
    17.02.2020
    20
    Default How to assign a certain entry in an archive to a variable?
    I have an archive for a certain variable, is it possible to creat a variable that reads and holds the value of a certain entry in the archive? (for example, the variable should hold the value of the most recent entry in the archive).
    I am using the 8.10 version of Zenon.
    Thanks in advance.
    15.11.2016
    108
    Default Re: How to assign a certain entry in an archive to a variable?
    Are you using an event triggered archive?
    if yes, you can use the archive trigger also as variable allocation trigger.
    BR,
    Georg
    17.02.2020
    20
    Quote Originally Posted by georgk View Post
    BR,
    Georg
    The archive I am creating saves the value of a variable at 00:00 every day. I need the latest falue of this archive to use it as a variable in other calculations.
    anything that can do this for me is fine.
    Can the event trigger be time? (i.e. when the global time is 00:00)
    10.12.2007
    261
    Default AW: How to assign a certain entry in an archive to a variable?
    You could use a report that is executed in the backgroud to do this.
    17.02.2020
    20
    Default Re: AW: How to assign a certain entry in an archive to a variable?
    Quote Originally Posted by mst View Post
    I opted to using the Report Generator + Variablerw function to achieve this.
  1. Is it possible to create one variable from archive?
    By michalt in forum zenon Service Engine Supervisor
    Last Post: 17th December 2018, 09:49
  2. Variable reaction matrix's limit text entry
    By dario in forum zenon Service Engine Supervisor
    Last Post: 7th May 2013, 06:59
  3. Assign function for key
    By mytom in forum zenon Service Engine Supervisor
    Last Post: 8th November 2012, 16:46
  4. Replies: 6
  5. There is a way to disable monitor assign function
    By shahramkh59 in forum zenon Service Engine Supervisor
    Last Post: 25th October 2009, 07:40
