Thread: Screen damage
    24.10.2019
    6
    Default Screen damage
    Dear all,
    I was working with Zenon Editor and after saving the project,
    the Zenon Editor shut down by itself.
    After to restart, the screen is damage.
    I canīt delete, change or open the screen.
    What could I do to solve this problem?
    995
    Default Re: Screen damage
    If you don't have Runtime historical data - recorded AML, CEL, Historians, etc. - you want to keep, then to cleanup the project from corrupt items you can try to make a project backup and restore from this backup as new project.
    If you have already important Runtime data recorded - contact your local COPA-DATA support. Probably the affected items are corrupted in the SQL databank of Editor. Manual operations in the databank demand experts knowledge.
    24.10.2019
    6
    Thank you ursulak,
    this backup tip worked.
    30.04.2010
    Good morning all!
    I have the same problem. I tried the ursulak's
    tip but it doesn't solve the problem, the corrupted screen is still
    present in the project ((
    Have you any other solution?
    Thanks in advance
  1. Screen title in header screen
    By yolovs in forum zenon Service Engine Supervisor
    Last Post: 20th September 2019, 12:24
  2. RTSP Video Screen type or HTML Screen type
    By veiga144 in forum zenon Service Engine Supervisor
    Last Post: 23rd June 2016, 10:48
  3. project data base driver C damage! how to recover database?
    By qiwenlu in forum zenon Service Engine Supervisor
    Last Post: 7th January 2013, 15:26
  4. Close one screen, opens other screen
    By dario in forum zenon Service Engine Supervisor
    Last Post: 14th November 2012, 10:34
