Hello, I've got a problem with report viewer. I need to archive values for each operator with time range 12h, 1 month and 1 year. I've got varrying number of operators (user can add or delete operators). For now only shift report is working for me. Inside Report Viewer: export/print I've set relative time filter at 12h and shift filter as "apply shift filter directly", then name: no filter, options: use found shifts: only last shift. Additionaly in data set I've set number of lines: 1 and aggregation as sum. I kindly ask for your help.
