Thread: straton program organization lost
    28.11.2017
    15
    Default straton program organization lost
    hi i open my straton IDE today
    click on my project list
    all my program are now in the same folder Programs before i had a folder organization for each
    where is this folder organisation stored ?
    folder organisation before:
Name:	straton before.png
    now:
Name:	straton after.png
    23.10.2018
    15
    Default Re: straton program organization lost
    The folders' architecture is stored in the project folder (click somewhere in the Project List then press CTRL+ALT+E), in the appli.xml file.
    Note that the best would be to be able to reproduce the problem, so we can fix it.
    /!\ Also note that this is not recommended to modify projects' files manually /!\
    In any case, before doing such a thing, think to duplicate the project in order to create a backup, or save it as a *.zip or *.xml:
     - Right-click on the project > Save Project > To zip
     or
     - Tools > Export > Export a complete project (XML)
    Anthony
    28.11.2017
    15
    in my appli.xml backup file i have the folder information:
    can i restore only that file ?
    23.10.2018
    15
    Quote Originally Posted by mos89 View Post
    I think, something went wrong and some information is missing in your post, but yes, basically if you want to change the project's architecture, you can only change/edit/restore (from a backup) this appli.xml file, and the architecture will be as it is described in the XML.
    If an item (eg. a program in a folder) is described in the XML but the source is not in the project's folder, this should not be a problem.
    Just think to close the project before changing the file
  1. IEC61850: connection lost but varaibles non updated
    By steven.costantini in forum zenon Energy Edition
    Last Post: 12th October 2016, 15:43
  2. IEC61850: connection lost but varaibles non updated
    By steven.costantini in forum Drivers
  3. multi monitor configuration lost if monitors switched off
    By wopmsc in forum zenon Supervisor
    Last Post: 3rd March 2014, 12:48
  4. Help Please - Lost file menu bar and cant get it back!
    By mattsd in forum zenon Supervisor
    Last Post: 23rd October 2007, 07:52
