Thread: Delete screen
    30.03.2017
    7
    Default Delete screen
    Hi
    I have a problem with a screen that I created, the zenon editor was closed and when I opened it again I could not see this screen (the name of the blank screen file appears), I only see it in the zenon runtime, there is some way to Can I import that screen from Zenon Runtime to my project?
    870
    Default Re: Delete screen
    There is no way to convert compiled Runtime project to its original design in Editor.
    I recommend to make project backups in Editor more frequently.
    If you have an (old) backup of the project you can restore it (e.g. as new project) and export the affected screen to XML. Then import this XML into current project.
  1. Alarms adminsitration-Context List Delete
    By sandeep2018 in forum zenon Supervisor
    Last Post: 3rd October 2019, 08:08
  2. Function scripts can not delete
    By skywalker in forum zenon Supervisor
    Last Post: 16th February 2016, 10:05
  3. Replies: 1
    Last Post: 13th January 2014, 14:43
  4. Delete structured tag
    By fabios in forum VBA
    Last Post: 28th July 2008, 14:39
  5. Delete item in a combobox
    Last Post: 11th July 2008, 10:43
