Thread: Systemmessages in eventlist
    11.04.2019
    16
    Default Systemmessages in eventlist
    Hi
    I have a migrated sicam230 Project running in Zenon 8.10.
    Whenever Runtime is started or stopped, I get a line in the eventlist saying $ SICAM230 started, or stopped.
    Where can I change this message to Zenon instead.
    870
    Default Re: Systemmessages in eventlist
    Is this a 'system message' or defined as limit by some SYSDRV variable?
    11.04.2019
    16
    I'm not sure, this is output from csv export of eventlist, first row is a breaker, then the system messages.
    I have not found any interal variables with limit values.
    2020-01-13 10:14:50.349;+HA9       S-LT2                    Brytare Indikering;FRÅN; Händelse;;;
    2020-01-13 10:15:25.813;;$ SICAM230 avslutades;;SYSTEM;;
    2020-01-13 10:19:34.789;;$ SICAM230 startades ;;SYSTEM;;
    870
    maybe you have "SICAM230 avslutades" (or similar, i'm not speaking Swedish) defined in the language table?
    zenon by Runtime start and exit writes info CEL (EN) "system was started" and "system was stopped". Any standard/system text used by the Runtime can be translated by the language table. Not translated looks like on my screenshot.
    11.04.2019
    16
    Lächeln Re: Systemmessages in eventlist
    Yes, I found it in the language file.
    Thank You for quick reply.
