Thread: Zenon Edior crash during restoring backup
    21.12.2016
    5
    Ausrufezeichen Zenon Edior crash during restoring backup
    Dear Sir/Madam,
    I am using Zenon 7.60 build 61612 Editor. While select editor zip file for restoration, Zenon Editor gives error and gets crash suddenly.
    I have attached error pic. and log files for your reference. Please check at your end and provide solution on it.
    LOG File.zip
    Sachin S
    Default Re: Zenon Edior crash during restoring backup
    Hi Sachin S,
    One thing that can be seen is from the log is an access denied error on the "C:\ProgramData\COPA-DATA\SQL2012\BACKUP" directory. This is something that you may be able to check on your system. Please make sure that there is sufficient free disk space available on the drive on which you are restoring this backup.
    If these are project backups of old(er) versions, the project may be affected by an issue where the SQL log file has grown to a very large size (gigabytes) with no actual content (the project backup itself is small, the extracted file could fill up the hard drive)
    The best really, would be to contact your local COPA-DATA support to get further assistance on this matter.
    21.12.2016
    5
    Ausrufezeichen Re: Zenon Edior crash during restoring backup
    Dear Sir,
    Thanks for your support. Restore project backup issue resolved.
    Sachin S
  1. zenon client crash
    By eden212 in forum zenon Operator
    Last Post: 28th October 2019, 09:05
  2. Replies: 3
    Last Post: 11th March 2019, 16:04
  3. Setting for Restoring PLC Value.
    Last Post: 9th September 2013, 00:09
  4. error on restoring a project backup
    Last Post: 31st March 2012, 09:26
  5. Backup 6.51 in zenon 6.50
    Last Post: 15th February 2012, 23:13
