Thread: why the numerical values take its colors from rema?
    michael_k Gast
    Default why the numerical values take its colors from rema?
    it's for me one important question,as I use the numerical value without the REMA assignment.my variable take its colors from property setting of numerical value.but when I assign the REMA to variable.it take its color from limit of REMA.
    is there the way to take its color from properties setting of numerical value,although I used the REMA in variable?
    Default Re: why the numerical values take its colors from rema?
    "as I use the numerical value without the REMA assignment.my variable take its colors from property setting of numerical value"
    Do you mean the "Limit color" from the variable here?
    michael_k Gast
    Quote Originally Posted by bernhardf View Post
    as I use numerical element with REMA assignment the property setting of numerical value for color is not used.and it take color from REMA
    michael_k Gast
    Quote Originally Posted by michael_k View Post
    i've attached sample project for simplicity
    with zenon 6.50 there is a new option "Use limit color" where you can activate and deactivate the functionality to take over colors from the limit (or REMA) at the link text and the numerical value.
    in previous versions (e.g. 6.22 SP1) this was not possible yet.
  1. Rema state
    By westbaaam in forum VBA
    Last Post: 30th November 2009, 06:32
  2. is the REMA editable in RT?(analog type)
    Last Post: 18th November 2009, 23:14
  3. problem with archive values in report
    Last Post: 20th October 2009, 13:40
  4. Sum of 2 variable values
    By dragosmoss in forum zenon Supervisor
    Last Post: 18th March 2009, 14:17
  5. Numerical Value display problem
    Last Post: 11th March 2009, 17:22
