Thread: Visual Studio, Config files and Zenon 7.6/8.0
    04.09.2019
    13
    Default Visual Studio, Config files and Zenon 7.6/8.0
    I have an app.config file which i use in my addin project.
    I am building my addin with visual studio and have set the
    properties of the app.config to copy always.
    When I build with Zenon 7.6 as reference in the project. The file is copied to the bin/Debug directory and renamed
    library.dll.xml. However when i unzip the addin, the config file is not included.
    Now interestingly if I use Zenon 8.0 as reference and do the same procedure, the app.config is renamed
    and put in the output directory, the config file is included in the scada addin.
    I dont know how visual studio uses the copa data developer tools  and zenon version as reference.
    I would like this to work using both zenon 7.6 and 8.0, any thought about this or is there any known
    problems using 7.6 zenon with visual studio and config files ?
    thanks,
    roger
    04.09.2019
    13
    Default Re: Visual Studio, Config files and Zenon 7.6/8.0
    I have removed the Zenon 8.0 from my computer and
    the system seems to work fine now. VS 2017 with config
    file seems to properly form the add in.
  1. AddIns and config files
    By roger_novarctech in forum Add-In Framework
    Last Post: 1st November 2019, 23:21
  2. Variable Change Event vb.net Visual Studio 2015
    By Thomas.Jahn in forum Add-In Framework
    Last Post: 2nd September 2019, 09:35
  3. web server zenon config location
    By eden212 in forum zenon Operator
    Last Post: 23rd January 2018, 12:54
  4. UnitTests in Visual Studio 2017
    By mmatanovic in forum Add-In Framework
    Last Post: 21st December 2017, 12:59
  5. Report-Visual Studio
    By MotionEngineering in forum zenon Supervisor
    Last Post: 6th September 2017, 07:44
