Thread: IEC61850 FileTransfer(COMTRADE) With Dynamic Text
    04.06.2017
    Idee IEC61850 FileTransfer(COMTRADE) With Dynamic Text
    Hi Everybody,
    When I send the DIR / COMTRADE command for file transfer, I get a long list.
    I'm trying to display this list with dynamic text, but it's not enough.
    What can I use instead of dynamic text
    How can I reverse-view the information that comes into the dynamic text?
    Can I reverse the list in the attached image?
    Version: 8.0 Energy Edition
    Thank you
    995
    Default Re: IEC61850 FileTransfer(COMTRADE) With Dynamic Text
    The order in the list is like delivered by the IED. This is like by another string variables received from a device. And there is no "post sorting". You see the real value in IED.
    To manipulierte the received string value you can use the API access.
    BTW, COPA-DATA customer services has already supported other customers by developing more automatic file transfer via IEC61850 protocol services DIR and GET. Maybe you would be interested to contact us officially?
    04.06.2017
    i contacted to your turkey branch, its solved this problem. But we couldn't speak for automatically "put and get comtrade files". Maybe i can ask again
    04.06.2017
    Quote Originally Posted by oeadeul View Post
    Hi Everybody,
    Thank you
    this problem is solved
    think about faceplate screen and create screen container
    we created a screen with only dynamic text in it
    added dynamic text screen in to the screen container
    At the "Dynamic Text screen" bigger than screen container
    at the runtime
    we can see whole page by turning the mause wheel
    995
    thank you for sharing your solution
  1. How can I use Filetransfer in IEC61850 Driver ?
    By bee in forum zenon Energy Edition
    Last Post: 10th February 2017, 09:31
  2. Dynamic limit text in Dynamic Text element
    By sdolnyy in forum zenon Service Engine Supervisor
    Last Post: 22nd July 2016, 12:57
  3. PDIAG alarms with dynamic text
    By leszkoo in forum Drivers
    Last Post: 29th February 2016, 08:03
  4. How to size a Dynamic Text Box
    By pilzfrance in forum zenon Service Engine Supervisor
    Last Post: 10th March 2014, 02:26
  5. Why Dynamic Limit Text allows only 1 variable?
    By batabaha in forum zenon Service Engine Supervisor
    Last Post: 1st May 2012, 23:51
