Thread: Creating variables in Scada addin.
    30.10.2019
    6
    Default Creating variables in Scada addin.
    Hi, I've been trying to create an intern variable using Scada addin
    I'm VariableCollection Create method like this:
    IVariableCollection myVariables = context.VariableCollection;
    IDataType myDatatype = context.DataTypeCollection["BOOL"]; // type of a variable I want to create
    IDriver myDriver = context.DriverCollection[6]; // index of a driver in which I want to create a variable
    myVariables.Create(bit_name, myDriver, ChannelType....., myDatatype);
    so far I was able to figure out everything except What is a ChannelType and which one to use when creating internal variable.
    Thanks in advance!
    28.02.2013
    221
    Default Re: Creating variables in Scada addin.
    Hi Isimas3,
    the ChannelType is an enumeration that identifies different driver object types: https://onlinehelp.copadata.com/help/810/addin/html/Variable-ChannelType.htm
    For internal driver it is enum item 33 which is SystemDriverVariable.
    So calling
    myVariables.Create(bit_name, myDriver, ChannelType.SystemDriverVariable , myDatatype);
    should bring you to the goal.
    Felix
    23.11.2016
    10
    Hello Isimas3,
    Actually, the tpChannelType is an enumeration for all the different specific variable types that are supported by the driver protocol.
    This means that not all enumeration values are available in the variable creation dialog for specific driver variables, however in the programming environment all these types are available.
    An overview of all the enumeration values of the channel types is available in the zenon help:
    ObjectModel Add-In --> Variable --> DataType
    For your example with the internal driver please use the following call:
    myVariables.Create("VariableName", myDriver, ChannelType.SystemDriverVariable, myDataType);
    As I mentioned above the channeltype strongly depends on the driver protocol. Due to the fact that the create-method is needed for variable creation in general, all ChannelTypes are available. But be careful because it might lead to an error if you for example want to create a variable with a ChannelType that is not supported by the driver protocol. For further information look in the specific driver help chapter.
    01.02.2016
    31
    Hello, all.
    How to create variable for MODRTU32 driver? Coil or Holding register for Driver object type?
    When i set ChannelType.DriverVariable, variable created but Driver object type is : Communication details
    BR,
    MK
    971
    According the documentation of the MODRTU32 driver the 'Driver object type' = "Coil" is the Channel Type = 65 (in Add-In docu it has no predefined member in tpKanaltypes constants), "Holding register" is 8 (in Add-In has member name PlcMarker).
    The 'Driver object type' = 35 (Add-In member name DriverVariable) in current zenon versions means "Communication details", but in old zenon versions was called "driver variable".
    disclaimer: i have no clue about C#, i'm just able to RTFM ;-)
  1. Using the Scada.Addin.Contracts API For XML Imports
    By Kyle in forum Add-In Framework
    Last Post: 15th May 2019, 07:35
  2. help with creating variables zenon 6.51
    By martinrelayer in forum zenon Service Engine Supervisor
    Last Post: 2nd March 2018, 18:51
  3. Assembly "Scada.AddIn.Contracts"
    By Ruebezaehler in forum Add-In Framework
    Last Post: 31st August 2017, 08:36
  4. Replies: 6
  5. Replies: 0
    Last Post: 5th January 2009, 15:13
