Thread: Access violation OPCUA32
    18.06.2021
    Ausrufezeichen Access violation OPCUA32
    What is the reason for the following error in file OPCUA32.txt?
    It happens at the closing the runtime
    zenOn Version: 8.20 SP0 Build80611
    Processor: x86
    Exception code: C0000005 ACCESS_VIOLATION
    Fault address:  004DF64A 01:000DE64A C:\Program Files (x86)\COPA-DATA\zenon 8.20\OPCUA32.exe
    and in the log file there is also "RCP error" for the driver, which is the meaning?
    1,030
    Default Re: Access violation OPCUA32
    The "RCP error" could mean that the zenon Runtime or the driver are too busy to exchange the data between each other.
    I propose you to contact the COPA-DATA Support officially, they will guide you to create the dump file of the driver during access violation, needed to analyze the issue.
  1. Replies: 2
    Last Post: 21st April 2020, 08:33
  2. Replies: 1
    Last Post: 23rd January 2018, 16:12
  3. Access violation
    By croc in forum zenon Service Engine Supervisor
    Last Post: 27th June 2014, 07:37
  4. Runtime Error C0000005 Access Violation
    By tomhul in forum zenon Service Engine Supervisor
    Last Post: 30th August 2012, 01:51
  5. Replies: 7
    Last Post: 8th May 2012, 10:46
