Thread: Automatic line coloring issue
    07.05.2018
    12
    Default Automatic line coloring issue
    Hi forum,
    I need some help for automatic line coloring. I am preparing a scada for switchgear with energy edition. I am using alc, but lines and symbols don't change according to alc configuration. The lines always shows like earthed, but the line is not earthed. I couldnt find the problem.
    839
    Default Re: Automatic line coloring issue
    I would propose you to make the energy training. It is available also online.
    07.05.2018
    12
    Hi Ursulak, thanks for your reply.
    I registered for online training, but I have non-normal problem. For example, I change something on editor and I am creating changes for runtime but not all of them. After finished, I am reloading the runtime and ALC on the runtime is not working according to configuration.
    839
    If your project does not behave in the Runtime like expected and you are not founding any topological/configuration mistakes in the Editor - send the project backup and description of the expected vs result to your local COPA-DATA support.
    To write "I change something on editor [..] I am reloading the runtime and ALC on the runtime is not working according to configuration." does not give information what you had configured and what you expect. By missing description I could only answer: when i'm configuring something (not only ALC, but anything) in my zenon Editor and compiling it - while the right project is the active one - then in the reloaded Runtime it works . Are you sure that in the Workspace the right project is the 'active' and it is the 'start project'?
  1. Coloring like lines
    By zeynal.sabas in forum zenon Energy Edition
    Last Post: 26th April 2018, 11:59
  2. Replies: 1
    Last Post: 9th March 2018, 09:08
  3. Automatic Line Coloring
    By yolovs in forum zenon Supervisor
    Last Post: 12th July 2013, 13:50
  4. How to invert DPI value and use it in topology coloring.
    By softart2 in forum zenon Energy Edition
    Last Post: 7th April 2010, 23:44
  5. Automatic line coloring (ALC) and DPI variables
    Last Post: 22nd July 2009, 14:12
