Thread: Ethernet/IP Server and Ethernet/IP/I/O Scanner
    02.02.2018
    8
    Frage Ethernet/IP Server and Ethernet/IP/I/O Scanner
    We have two straton running on two different PC's one is act as Ethernet/IP Server and another is Ethernet/IP/I/O Scanner.
    As per given in help we have configured the required settings(e.g. instance, attribute)in both scanner and server but still we are not able to achieve data transfer between them. So is there any
    manual or help files which we can follow to achieve the required result.
    15.01.2018
    3
    Default Re: Ethernet/IP Server and Ethernet/IP/I/O Scanner
    Please find attached a tutorial how to configure the Ethernet/IP Scanner in zenon Logic/straton
    Please consider the following for the configuration of the Ethernet/IP Adapter in zenon Logic/straton:
    In the Fieldbus Configurations under Ethernet/IP adapter enter for IP address the ip address of the network interface on your workstation which is used for communicating via Ethernet/IP within your network.
    For I/O: Inputs (Target to originator) and I/O: Outputs (Originator to target) ensure that the values for Instance and size match those on the Ethernet/IP Scanner side.
    For the variables within I/O: Inputs (Target to originator) and I/O: Outputs (Originator to target) ensure that the values for Offset, Bit and Format match those on the Ethernet/IP Scanner side.
    Kind Regards,
    Christopher Kern
  1. Replies: 0
    Last Post: 15th June 2018, 23:37
  2. Replies: 4
    Last Post: 2nd November 2017, 13:58
  3. Dual Ethernet Port in Runtime PC
    By andrigunawan in forum zenon Network
    Last Post: 28th November 2014, 15:15
  4. Replies: 4
    Last Post: 18th October 2012, 09:15
  5. Ethernet IP Communication
    By amolck in forum straton / zenon Logic
    Last Post: 15th March 2010, 06:11
