Thread: Threaded Project Wizard extension
    30.10.2019
    6
    Default Threaded Project Wizard extension
    I ran into a problem, when I launch an addin from zenon runtime. runtime freezes. It makes sense, because both the addin and the runtime run in foreground thread. So I read that I should run addin on different thread, however I couldn't find any example on how to do it.
    Any help will be highly appreciated!!!
    28.02.2013
    176
    Default Re: Threaded Project Wizard extension
    Dear Isimas3,
    general information about asynchronous .NET programming can be found here: https://docs.microsoft.com/en-us/dotnet/standard/async
    Examples for zenon related programming can be found on github: https://github.com/copa-data
    Felix
  1. Project wizard extension in eigenem Thread ausführbar?
    By ma01234 in forum Add-In Framework
    Last Post: 26th March 2019, 12:29
  2. Replies: 1
    Last Post: 30th August 2018, 09:33
  3. Replies: 12
  4. ZENON *.prj files extension
    By markuska in forum zenon Supervisor
    Last Post: 18th June 2010, 11:07
  5. Replies: 0
    Last Post: 20th August 2007, 13:08
