Thread: Populating ListBox with a list created in ScadaAddin.
    30.10.2019
    6
    Default Populating ListBox with a list created in ScadaAddin.
    I was wondering is it possible to populate a ListBox element in Runtime with a list created in ScadaAddin. And if it is possible then how should I do it? Thanks in advance.
    28.02.2013
    222
    Default Re: Populating ListBox with a list created in ScadaAddin.
    Hello Isimas3,
    yes, you can configure a listbox to derive it's content from a string variable. So to modify the content of the list box you only need to modify the content of the linked string variable via AddIn.
    Felix
    30.10.2019
    6
    Thanks. it worked.
    firstly I declared IVariableCollection with:
    IVariableCollection myVariables = context.VariableCollection;
    then I simply wrote value to each variable with:
    if (myVariables[devi] != null)
                    myVariables[devi].SetValue(0, state);
  1. Using Zenon 8.20 variables in scadaAddin script
    By lsimas3 in forum Add-In Framework
    Last Post: 31st October 2019, 08:48
  2. dynamic ListBox Created.
    By jahyun100 in forum VSTA
    Last Post: 12th July 2017, 11:33
  3. Max.Storage time of Alarm Message list & Chronologic event list
    Last Post: 20th October 2013, 23:53
  4. Convert runtime created fpm.cmp
    By brc in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 9th May 2013, 03:25
  5. automatically created limits
    Last Post: 20th August 2007, 10:21
