Thread: Hexadecimal to ASCII Coversion
    14.09.2017
    16
    Default Hexadecimal to ASCII Coversion
    Can we convert Hexadecimal input to ASCII output using standard block in Straton?
    e.g I need to convert '31 32 33 34' to ASCII as "1234" and likewise others.
    Thanks & Regards,
    Rahul.
    23.10.2018
    14
    Default Re: Hexadecimal to ASCII Coversion
    The only way I know to convert the hexadecimal representation of a character to the character (Eg. 0x31 to '1') is to use two consecutive blocks:
    ATOH and then CHAR. ATOH will convert '31' (decimal) to 49 (hexa) and then CHAR will convert 49 to '1'
    But there is notghing ready to use for this usecase, you will have to create your own block (function or UDFB)
    All useful blocks you may need are all under the "Strings" folder, in the block's list (bottom-right of the straton/zenon-Logic Editor, while a program is open)
    Anthony
  1. Replies: 7
    Last Post: 30th May 2018, 09:36
  2. Dynamic limit texts with hexadecimal value
    By lew in forum zenon Supervisor
    Last Post: 9th January 2012, 00:41
