Thread: Auto Load Recipe.
    Default Auto Load Recipe.
    Hi all,
    I am using RGM for recipes. I want to know (if possible) how to auto load a selected recipe when the run time starts.
    The reason for doing this is because in b&r PLC they have configurable input output mapping (if emergency ip is assigned to Input 0 then in run time it can be changed to input 1)
    So when the Zenon scada run time starts it should automatically load a particular recipe which will have emergency assigned to input 0. This is one example in this case.
    Also is It possible to show User through Drop down menu since every time user has to logout and again enter the username.
    Zenon version 7.60
    Regards
    Nivish.
    15.01.2016
    90
    Default Re: Auto Load Recipe.
    Hello nivish,
    For executing functions at start of the runtime you can use the zenon Autostartscript but i am not sure if there is a function to execute a recipe:
    For the user login i am not sure but i think there is no such possibility like a drop down list at the moment.
    Tobias Ritschel
    Thanks a lot for the solution i will try it out.
    Regards
    Nivish
  1. Replies: 2
    Last Post: 27th November 2019, 10:30
  2. Trends taking too much time to load
    Last Post: 4th February 2013, 13:47
  3. Load projects during zenOn startup
    By matteo.fabbri in forum VSTA
    Last Post: 18th September 2012, 00:14
  4. Load on CPU
    Last Post: 8th October 2011, 09:27
  5. display the load changing
    Last Post: 1st February 2010, 00:35
