Thread: Using drivers from zenon Supervisor in SICAM 230
    09.05.2013
    49
    Default Using drivers from zenon Supervisor in SICAM 230
    Is it possible to use drivers from zenon Supervisor in SICAM 230?
    I need to use MODBUS TCP and SNMP driver.
    Should I integrate the driver in file Treiber_EN.xml in folder C:\ProgramData\SIEMENS\SICAM230711?
    Does some on got an experience about it?
    regards,
    Svetozar Yolov
    816
    Default Re: Using drivers from zenon Supervisor in SICAM 230
    SICAM 230, especially in Energy, follows another philosophy as zenon. Thus, even if you force the zenon native driver to start together with SICAM 230 Runtime, there is no guarantee that there will be no some strange effects. I would not risk a mixed constellation for a final system, working then in a real utility.
  1. zenon logic to zenon supervisor
    By MJ in forum zenon Supervisor
    Last Post: 26th July 2019, 10:25
  2. Zenon supervisor
    By Otmane2019 in forum zenon Supervisor
    Last Post: 23rd April 2019, 07:25
  3. Drivers won't start
    By dlumbar in forum zenon Supervisor
    Last Post: 11th January 2018, 09:13
  4. Load Management in Zenon Supervisor
    By kingsley in forum zenon Energy Edition
    Last Post: 5th April 2016, 07:47
  5. Replies: 5
    Last Post: 25th February 2013, 15:43
