Showing results 1 to 8 of 8
Thread: Report Archive N_UPDATE
    20.12.2017
    9
    Default Report Archive N_UPDATE
    Can You explain me what does mean N_UPDATE status in Report Viewer Archive, because what I have found on this forum is explained in one line
    'Responisble project server/standby is not delivering values for the affected variabe.'.
    Does tht mean that my application does not have valid communication with the main server?
    I am using MODRTU32 drivers.
    Best Regards,
    Damir
    28.02.2013
    170
    Default Re: Report Archive N_UPDATE
    Dear Damir,
    yes, it seems that the zenon runtime which is creating the archive is a client to a zenon runtime server and does not recieve a valid value.
    See also our manual section "Status processing"
    How is your project configuration regarding the network topology?
    Felix
    20.12.2017
    9
    Hi Felix,
    it should be server client.
    Looking  at the License ZEE7-SRV-1500, should I try to enable IIS in programs and features, and see if I can define server name in inetpub/root/config.js?
    BR,
    Damir
    28.02.2013
    170
    Dear Damir,
    no IIS is not needed for zenon network. Please check if name resolution and network connection between your server and client is working and if the server name is configured properly in the zenon project.
    Felix
    20.12.2017
    9
    Hi Felix,
    it is a standalone application. Since is like that, network active should be unchecked like it is shown in image in attachment?
    Regarsd,
    Damir
    810
    maybe you mistakenly have activated by variables the setting 'Addressing' - 'Driver connection' - 'Read from Standby Server only'
    28.02.2013
    170
    Dear Damir,
    has this option always been unchecked? Even for all sub-projects?
    So you are getting values with the N_UPDATE status in standalone projects?
    As far as I know, this bit should not be set by MODRTU32 driver and therefore only by zenon networking mechanisms.
    For deeper analysis confidential project configuration details might be needen and therefore I suggest to contact you local COPA-DATA support representative for further investigation.
    Please include zenon version and build number and also point them to this discussion here.
    Felix
    20.12.2017
    9
    Hi Ursula and Felix,
    I have not activated 'Addressing' - 'Driver connection' - 'Read from Standby Server only' , it is unchecked.
    we had some issues with communication, today we solve it, and now status is SPONT, and I have read in one forum post that variable with legal value have bit SPONT.
    (thread link:
    https://forum.copadata.com/showthrea...ighlight=SPONT)
    If this is corect, than this issue is solved.
    Thank You both for the support.
    Damir
  1. time filter of report for following archive
    By roberto1978 in forum zenon Supervisor
    Last Post: 22nd March 2017, 13:06
  2. N_UPDATE Statusbit erkennen
    By genakust in forum zenon Energy Edition
    Last Post: 26th April 2016, 10:49
  3. Zenon archive issue (archive inactive)
    By eugenius in forum zenon Supervisor
    Last Post: 24th August 2012, 08:19
  4. Archive report
    Last Post: 10th August 2011, 02:34
  5. problem with archive values in report
    Last Post: 20th October 2009, 13:40
