Thread: Batch Control Recipes production report
    25.10.2019
    7
    Default Batch Control Recipes production report
    I am
    new in working with Zenon.
    I want
    to make a production report of every recipes. I suppose to display some of the variable
    changes in this report.
    I tried to make a different Archive for every recipe but unfortunately
    it did not work. I tried "lot" and start from specific time but the Problem
    is I cant save Archives in respect of the Name of recipe
    and on the
    other hand read the data.
    I will be grateful if you can give some hints about this issue.
    Thank you in Advance
    25.10.2019
    7
    Default Re: Batch Control Recipes production report
    it is Basic but Maybe it is somebody's Problem. I found out i should do this steps:
    1- start recording data with recipe start Signal.
        you can use internal Signal
    2- put the Name of Archive in Lot Name in Archive Setting.
        a Little bit tricky but it depends on your Project.
    3- stop recording data with recipe stop Signal.
        you can use internal Signal.
  1. Stop alarms during no production
    By sandeep2018 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 20th June 2019, 12:38
  2. Replies: 9
    Last Post: 24th October 2017, 10:40
  3. Production & Facility Scheduler: Unhandled Exception Error
    By drehpet in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 14th October 2016, 08:58
  4. Archives (RT) - Read batch information
    By herberto in forum VBA
    Last Post: 25th July 2011, 14:09
  5. How does the batch archive gets its name?
    By bernhards in forum zenon Pharma Edition
    Last Post: 21st August 2007, 08:59
