Thread: Unencrypted connection
    03.03.2019
    19
    Default Unencrypted connection
    Hi guys,
    I don`t know exactly what is the cause of a problem, but when I open a VNC session to comp with Zenon 8.0 RT app on, a message "Unencrypted connection" is showed out, and after I launch Zenon RT, a sort of a fire sign appears in the command line menu (see enclosed screenshot).
    I that has something to do with Zenon settings or it`s just another Windows 7.0 issue? Thanks for help in advance!
    banpr1
    15.01.2016
    90
    Idee Re: Unencrypted connection
    Hello banpr1,
    For the VNC connection i cant say much because you probably using one provided by your it department. But the task with the fire symbol looks like an alarm in the zenon Alarm message list if you acknowledge that alarm the task should disappear.
    Tobias Ritschel
    03.03.2019
    19
    Default Re: Unencrypted connection
    Hi Tobias,
    Thanks for the hint. I thought that the fire symbol is about the unencrypted connection. VNC is not the matter.
    banci
  1. Connection to zenon
    By churras in forum straton / zenon Logic
    Last Post: 14th February 2020, 16:28
  2. Connection to Codesys v.3 PLC
    By peternn in forum zenon Supervisor
    Last Post: 17th October 2017, 11:05
  3. Connection to IED
    Last Post: 24th October 2014, 09:29
  4. WebServer connection
    By abcd1234 in forum Webserver/Webclient
    Last Post: 15th January 2014, 15:57
  5. Winsock connection
    By michael_k in forum Drivers
    Last Post: 26th March 2012, 23:48
