Thread: Language change with ENG operative system
    13.02.2019
    30
    Default Language change with ENG operative system
    I have a question.
    If I use an OS with "Eng" system language and I would like to see the text on zenon (ALM,CEL entry...) for example in Italian language,
    Do I need to use the "System text language translator wizard" or instead of there is another method?
    Thank you
    09.03.2011
    44
    Default Re: Language change with ENG operative system
    Hi doublem,
    If you want to change "System texts" then yes, use the "System Text Wizard" will be the fastest way, so you will have a language table with these words. But you can also create your own language table with only the words that you want to translate.
    And then you will have to use the zenon "Language switch".
    You can find more information on the help.
    Steffi
    Attached Thumbnails Attached Thumbnails SystemTextWizard.png   LanguageSwitch.png
  1. system table version change possible?
    By saravanan1985 in forum Editor and Runtime Setup
    Last Post: 19th May 2018, 06:26
  2. Change user authorization system screen
    By davpe in forum zenon Supervisor
    Last Post: 23rd April 2018, 10:51
  3. system table version change possible?
    By saravanan1985 in forum zenon Energy Edition
    Last Post: 18th December 2017, 07:51
  4. Detect Language Change
    By yavaskoray in forum VSTA
    Last Post: 6th August 2013, 13:02
  5. Change Language with user login
    Last Post: 23rd April 2010, 10:03
