Thread: Connecting to a Modscan in same computer
    Default Connecting to a Modscan in same computer
    If I want to establish connection to a modscan32 software residing in the same computer as Zenon Server, what setting in the Modbus Energy Edition Driver?
    25.06.2012
    155
    Default Re: Connecting to a Modscan in same computer
    Dear saravana.b@peak-national.com,
    Welcome to COPA-DATA Forum.
    Modscan32 is a MODBUS Master so that the MODBUS_ENERGY driver cannot connect to it. Regard that zenon MODBUS_ENERGY and MODRTU32 drivers are MODBUS masters as well.
    Nevertheless, in zenon there are two options that can be used as Modbus Slave:
    1. zenon Process Gateway Modbus Slave.
    2. zenon Logic Modbus Slave Fieldbus.
    You can find more information in the respective modules configuration:
    1. Manual > Process Gateway > MODBUS Slave
    2. (zenon Logic online documentation) IEC 61131-3 Programming Environment > Drivers - Fieldbus configuration > MODBUS networking
    Good luck.
    David Cerdeira
  1. Operator Extended Trend not displaying on RT computer
    By strobo5 in forum zenon Operator
    Last Post: 9th October 2018, 04:58
  2. Issue connecting ZENON 7.11 to S7-1200 (Programmed with TIA portal)
    By Sonia in forum Editor and Runtime Setup
    Last Post: 8th January 2018, 13:15
  3. Executing a function based on computer name
    Last Post: 20th November 2008, 20:17
