Thread: Combi Element
    29.08.2009
    LEGAZPI CITY
    56
    Default Combi Element
    I want to utilize the combi element for breaker symbol " breaker close position- blue color ( energized and close position) " with this scenario
    two variables will be linked to 1- combi element. The variables are 1- boolean and 1- analog variable, the breaker will closed and turned blue when it sensed that status ( boolean ) is closed and there is already voltage ( analog) .
    I know its possible with but I run out of idea..Thanks!
    Default Re: Combi Element
    you are right, this is possible
    You can add additional variables to the combi-element and use a formula to define the conditions.
    Take a look at the screenshot below:
    29.08.2009
    LEGAZPI CITY
    56
    I used the wrong formula { X01.Status AND (X02.Value > 0) } that why it always failed. I should used the value bit of the boolean not the status.....
    Thanks for the information Mark!
    29.08.2009
    LEGAZPI CITY
    56
    Hi Mark!
    How about a combi element with two boolean linked? For example for 3-position switch symbol..
    1st condition- switch is open ( color is green) when variable-A is 0 value
    2nd condition- switch is close ( color is red) when variable-A is 1 value
    3rd condition- switch is open and earthed ( color is yellow) when variable-A is 0 value and variable-B is 1 value
    I used the formula in 3rd condition
    (X01.00 = 0)AND X02.00
    but it did not worked..
    Any idea?? Thanks again!
    19.11.2009
    8
    Write the formula as {X02.00 AND NOT X01.00}.
    And do not forget to click on the first bit, so to have point {.} instead of 0 or 1.
    Nikos
  1. Create an Element
    By robertf in forum VBA
  2. How to put comment on dynamic element?
    Last Post: 5th November 2009, 14:25
  3. What’s the reason for freezing the value of dynamic element?
    Last Post: 25th August 2009, 09:55
  4. Animating a vector element
    Last Post: 7th May 2009, 13:36
  5. Message element
    Last Post: 10th March 2009, 16:25
