Thread: Bargraph color fill and lenght from two different variables
    05.10.2018
    Idee Bargraph color fill and lenght from two different variables
    Hi All
    I need to have a bargraph with this configuration:
    VAR1 (range 0-100) : set the foreground fill level (variable/function variable)
    VAR2 (range 1-5) :  set the foreground fill color with 5 different colors
    • I can change the color of the bar via limit value, but this will use the value of VAR1 itself, not Var2
    • In the fill property I can set the background fill color.. not the foreground
    Issue: Bargraph shall change color based on limit values of a different variable
    Any suggestion?
    10.12.2007
    182
    Default AW: Bargraph color fill and lenght from two different variables
    I think this is not possible with the bargraph element, but as your VAR2 seems to have only 5 steps, you could place 5 bargraphs with the different colors on top of each other and make them visible by the 5 different VAR2 values
  1. Comparison of two string variables to activate color
    By TMeck9 in forum zenon Supervisor
    Last Post: 23rd January 2019, 09:08
  2. Replies: 0
    Last Post: 28th March 2018, 09:59
  3. NXT Color Sensor
    By arueger in forum zenon Science Package for LEGO MINDSTORMS
    Last Post: 17th September 2014, 12:24
  4. CEL- text color
    Last Post: 21st December 2009, 11:38
  5. Object Fill (ie Tank)
    Last Post: 27th May 2009, 07:18
