Thread: TIA project cannot be loaded
    03.03.2019
    17
    Default TIA project cannot be loaded
    Hi guys,
    I`ve tried to create S7-1200/1500 PLC driver with symbols from TIA V15.1 version project and got the message "TIA project cannot be loaded".  Is there a sort of interop problem with TIA V15.1 release and Zenon 8.0 or I missed something? Please help me to solve this issue. Screen shots are enclosed. Thanks in advance!
    Primoz
    Attached Thumbnails Attached Thumbnails Screenshot_Driver#1.PNG   Screenshot_Driver#2.PNG   Screenshot_Driver#3.PNG
    25.06.2012
    155
    Default Re: TIA project cannot be loaded
    Hello Primoz,
    It should be possible to open TIA 15.1 projects since zenon 8.00 build 53974.
    Unfortunately, the error message displayed is too vague so that multiple reasons can produce the same:
    - File is blocked because is open in other program (TIA Portal)
    - Editor does not have access to the specified folder
    - Project file is corrupted
    If still you are not able to open the project in zenon please contact your local Support Team for assistance.
    David Cerdeira
    03.03.2019
    17
    Hi David,
    I managed to find a workaround solution for that issue. The thread can be closed. Thanks for the offered support.
    banpr1
  1. Recipe not loaded properly
    By jneuhaus in forum straton / zenon Logic
    Last Post: 18th September 2018, 09:44
  2. <Project 'F_GP7' not loaded>
    By iweinclaerhout in forum zenon Supervisor
    Last Post: 12th August 2014, 16:12
  3. zenon CE - BeckhNG.dll could not be loaded
    By ptkdennis in forum Drivers
    Last Post: 16th April 2014, 07:53
  4. Replies: 6
    Last Post: 21st January 2014, 11:45
  5. Variable was not loaded
    Last Post: 12th February 2009, 13:15
