Thread: Screen Type specific functions
    04.09.2019
    13
    Default Screen Type specific functions
    Is it possible to find out what the screen type specific functions are doing ?
    Ie what variables they are writing etc
    I would like to effectively do what set procedure does in the recipes screen type.
    In the editor when i dbl click on the element I see that the write recipe function is linked
    but how can I find out what this is doing ?
    thanks,
    roger
    23.11.2016
    10
    Default Re: Screen Type specific functions
    Hello rogar_novarctech,
    there is actually no way to look into the functionality of screen specific functions in that case. (counts for any other screen specific function as well)
    Are you referering to the screen type "Standard Recipes"?
    As far as I am aware the write recipe function basically writes the configured set values of the selected standard recipe.
    Please check out the API method SendValues which might be the functionality you are searching for: https://onlinehelp.copadata.com/help/800/addin/html/Recipe-IStandardRecipe-SendValues.htm
    I hope that helps.
    Michael
    04.09.2019
    13
    hi,
    Its possible that I could use SendValues but what values does it send
    it takes no parameters ...
    I have the recipe name and I can find the associated recipe in the StandardRecipeCollection
    but how do I use this with SendValues ?
  1. RTSP Video Screen type or HTML Screen type
    By veiga144 in forum zenon Supervisor
    Last Post: 23rd June 2016, 10:48
  2. Extended curves - Frame Specific Functions
    By bastien in forum zenon Supervisor
    Last Post: 27th August 2015, 11:03
  3. screen type-specific function in WPF
    By sabbonis in forum VSTA
    Last Post: 9th February 2014, 16:05
  4. Replies: 1
    Last Post: 24th April 2013, 04:50
  5. Open function on specific screen
    By softart2 in forum VSTA
    Last Post: 2nd June 2011, 04:23
