Thread: Flashing Polygon
    19.06.2019
    Default Flashing Polygon
    I'm trying to figure out the Zenon basics. However I'm currently struggling with something trivial.
    I have created a Polygon and would like to make it flash red/grey when a bit is set.
    Simply using the "flashing" property of the rectangle and linking the bit to it doesn't seem to work.
    15.01.2016
    88
    Default Re: Flashing Polygon
    Hello Bernard,
    Welcome to the world of zenon.
    For your usecase you need a variable with a limit or reaction matrix there you can set the values for blinking.
    For some more Basics we also have a playlist on the CopaData Youtube chanel check it out
    https://www.youtube.com/user/copadatavideos/playlists
    Tobias Ritschel
  1. Polygon as Button or polygon shaped button.
    By bortdegraaf in forum zenon Supervisor
    Last Post: 27th August 2019, 08:20
  2. Button flashing
    By tihomir in forum zenon Energy Edition
    Last Post: 25th April 2013, 13:00
  3. flashing when value change
    By focus in forum zenon Supervisor
    Last Post: 23rd January 2012, 00:11
  4. Reset Flashing
    Last Post: 17th May 2011, 00:15
  5. Resettting Flashing of Elements
    Last Post: 22nd April 2011, 00:09
