Thread: WPF elements in HTML5
    01.07.2019
    14
    Default WPF elements in HTML5
    I would like to know, if WPF elements, like gauges, bars etc., are supported by HTML5.
    Thank you in advance for your answer.
    25.06.2012
    157
    Default Re: WPF elements in HTML5
    Dear grzegorz_kaczmarczyk,
    Unfortunately, AddOn’s like ActiveX or WPF Elements are not supported by the HTML5 technology.
    You can find the list of functionalities and elements supported in HTML5 in the documentation topic (inc. subtopics) below:
    Manual > HTML Web Engine > Engineering in the Editor > Supported functionalities for HTML visualization
    Good luck.
    DC
    05.01.2021
    In this section, I will explain how you can use the gauge control in your application. The easiest way to get started would be to copy this template code snippet in your project after referencing CircularGauge.dll and the CircularGauge namespace.
    Hide   Shrink    Copy Code
    <!--Black Gauge -->
    <gauge:CircularGaugeControl x:Name="myGauge1"
      Grid.Column="0" Grid.Row="0"
      Radius="150"
      ScaleRadius="110"
      ScaleStartAngle="120"
      ScaleSweepAngle="300"
      PointerLength="85"
      PointerCapRadius="35"
      MinValue="0"
      MaxValue="1000"
      MajorDivisionsCount="10"
      MinorDivisionsCount="5"
      CurrentValue="{Binding Score}"
      ImageSource="silverlightlogo.png"
      ImageSize="60,50"
      RangeIndicatorThickness="8"
      RangeIndicatorRadius="120"
      RangeIndicatorLightRadius="10"
      RangeIndicatorLightOffset="80"
      ScaleLabelRadius="90"
      ScaleLabelSize="40,20"
      ScaleLabelFontSize="10"
      ScaleLabelForeground="LightGray"
      MajorTickSize="10,3"
      MinorTickSize="3,1"
      MajorTickColor="LightGray"
      MinorTickColor="LightGray"
      ImageOffset="-50"
      GaugeBackgroundColor="Black"
      PointerThickness ="16"
      OptimalRangeStartValue="300"
      OptimalRangeEndValue="700"
      DialTextOffset="40"
      DialText="Black"
      DialTextColor="Black">
    </gauge:CircularGaugeControl>
    The CircularGauge control has several options to completely customize all its elements. Most of the property settings are intuitive to use, so I would discuss whatever I knew here. I also learn web designing course and HTML from CETPA.
  1. HTML5 und Redundanz
    By horstd in forum HTML5 Configuration
    Last Post: 7th August 2019, 14:00
  2. Redundancy & HTML5
    By joelprasad in forum HTML5 Configuration
    Last Post: 5th August 2019, 15:03
  3. Problem Facing on HTML5
    By AJAY KUMAR CHEKKA in forum zenon Supervisor
    Last Post: 29th April 2019, 09:28
  4. HTML picture supporting HTML5 and CANVAS
    By maurodx in forum zenon Supervisor
    Last Post: 25th November 2015, 16:29
