Thread: Additional Data Folder Created with remote pc name while running zenon From remote PC
    21.02.2019
    Default Additional Data Folder Created with remote pc name while running zenon From remote PC
    Dear Sir,
    I am using Zenon Supervisor 7.60 Build 56718 while i take my IPC remote with remote desktop and run the zenon from remote pc it is creating new data folder with remote pc name so i am having 2 data folder one from my IPC name and another from remote Pc name because of that my some data files are getting corrupted .
    Kindly Provide Solution For this problem.
    Thank You
    Default Re: Additional Data Folder Created with remote pc name while running zenon From remote PC
    Hi gaurav7376,
    On the system with the runtime, the terminal server registration is active. You can use the startup tool to perform a standard registration so that the runtime uses the local host name instead of the host name of the remote desktop session.
    21.02.2019
    Hi gaurav7376,
    Thank You Sir Your solution solved my problem.
  1. Remote OPC DA Server with Zenon OPC Client
    By jose.torres@indexum.com in forum Drivers
    Last Post: 25th February 2020, 13:38
  2. Zenon Remote Runtime Driver Issue
    By Diana7310 in forum zenon Supervisor
    Last Post: 7th August 2018, 09:49
  3. Remote transport
    By tihomir in forum zenon Energy Edition
    Last Post: 10th May 2013, 08:13
  4. Remote Transport Window will not Dock in Zenon program software
    By mattsd in forum Editor and Runtime Setup
    Last Post: 27th January 2012, 07:55
  5. remote transport
    By stephanepilon in forum zenon Supervisor
    Last Post: 5th May 2008, 08:13
