Thread: Getting and Setting Values in Standard Recipes
    04.09.2019
    2
    Beitrag Getting and Setting Values in Standard Recipes
    What would be the best way to get/set values in the Standard Recipes?
    I have a Standard Recipe Collection which includes pipe "Size" and "Schedule" entries and if these match my target values, I want to set a "Selected" value as true. Please see the draft below.
    I am using the GetDynamicProperties method, but I am not sure that is the right way to do it.
    IStandardRecipeCollection standardRecipes;
    // The Standard Recipe Collection is extracted from the context.
    foreach (IStandardRecipe recipe in standardRecipes)
    bool match = false;
    try
    Int32 sched = Int32.Parse(recipe.GetDynamicProperty("Pipe_Schedule").ToString());
    Double diameter = Double.Parse(recipe.GetDynamicProperty("Size_Of_Pipe").ToString());
    if (Int32.Parse(recipeFilter.mSchedule) == sched &&
    Double.Parse(recipeFilter.mDiameter) == diameter)
    match = true;
    recipe.SetDynamicProperty("Selected", match);
    catch ()
    04.09.2019
    2
    Default Re: Getting and Setting Values in Standard Recipes
    using Scada.AddIn.Contracts.Recipe;
    using System;
    using System.Collections.Generic;
    using System.Text;
    namespace NovarcStratusInterface
        public class ZenonRecipes : INvRecipes
            public ZenonRecipes(IStandardRecipeCollection standardRecipeCollection)
                standardRecipes = standardRecipeCollection;
            // match function should match any and all recipes in the system and
            // modify zenon vaiables as needed
            public void Match(RecipeFilter recipeFilter)
                // go through all recipes and check if match
                    bool match = false;
                    try
                            match = true;
                    catch (ArgumentNullException)
                        // put out a log
                        // set match  to false
                    catch (FormatException)
                        // put out a log
                    catch (OverflowException)
                        // put out a log
  1. Replies: 2
    Last Post: 1st May 2019, 11:49
  2. recipes password
    By aleb2 in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 19th December 2016, 15:16
  3. Replies: 0
    Last Post: 26th January 2015, 12:36
  4. Setting transient values to 0
    By knubla in forum zenon Energy Edition
    Last Post: 26th May 2014, 10:04
  5. copy recipes
    By hicom in forum Engineering Studio & Service Engine (former zenon Editor & Runtime)
    Last Post: 11th May 2009, 05:28
